PROS
I have all the documentation of all the repairs of the car for the past 14 years
Engine has only 187k miles
New transmission that had 40k miles on it when it was installed at 150k miles
New starter 2011
New alternator in 2012
New rear rotors 2011
CONS
Has oil leaks from many places but they are all small (I never have to put any oil in between changes)
Smokes from oil leaks (Can't notice while your driving but when you come to a stop it will start smoking)
Busted off lugnut
Needs a new tire (Tire could not be patched, that's why it has a donut on)
Leaks from sunroof/windshield (Needs new seals)
Has a crack in sunroof
Sunroof doesn't open or close (Needs new motor)
Drivers side automatic seat belt doesn't go down or up (I think it's the motor)
Needs new muffler (I have it patched right now, you can see in the photos)
Has some body damage from 4 hit and runs over the last 14 years (Doesn't affect driving, check photos)
I sanded down and bondo and repainted the car, it was my first attempt so it's not pretty
Has some rust above driver side wheel well/driver side door/driver side headlight
Trunk doesn't stay latched (I can get it to close if I bend the lock but it still pops open sometimes)
Trunk key is broke off in the trunk key hole (Still opens, but any key can turn it)
Hood can be fickle opening (Sometimes you need someone to hold the Open Hood lever for it to pop open)
Needs AC belt (Possibly a recharge but I doubt it)
[imghttp://i.imgur.com/Yj1CQdR.jpg][/img]
