WTB: Turbo legacy front harness (from ecu to engine)
nortonjefferson
Hi everyone, as the title implies I am looking for a full legacy ss front harness, the part of the harness that goes from the ecu to the engine bay. I am located in western Washington, local pickup would be more than stellar but I'll take what I can get. Thanks for your time!
White 1993 L Wagon AWD 5MT-FXT lift, 27” MTs 380xxx miles
White 1991 L sedan AWD 5MT-(Robtune 550 DOHC Ej22t swap coming together) 187xxx miles
Black 2005 LGT 5MT-Ej20x swapped daily, VF40/elh
Re: WTB: Turbo legacy front harness (from ecu to engine)
You checked the local junkyards?
nortonjefferson
Yes i have and unfortunately (or is that fortunate?) i never ever can find a turbo legacy at my local yards. Tons of n/a first gens but no turbos it seems.mike-tracy wrote:You checked the local junkyards?
Try NW recycling off Machias road in unincorporated Lake Stevens. They had a 94 white turbo wagon 2 weeks ago.
Pntaste4evr99
- Winestone Cowboy
That wagons gone, I was there last Sunday after the game....
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
nortonjefferson
Shiit, i heard about that car from a few buddies who spotted it but no one told me it was a turbo haha oh well
I appreciate the feedback!
If you're talking about the harness that routes under the driver's fender I may have what you need. I'll dig it out this weekend and get you some pictures. It might be missing a couple non important connectors (light or abs)
nortonjefferson
Oh man i would appreciate that so much! Thats exactly what im talking about, I dont have abs or any of that anyways. Thank you for letting me know! ill keep in touchcj91legss wrote:If you're talking about the harness that routes under the driver's fender I may have what you need. I'll dig it out this weekend and get you some pictures. It might be missing a couple non important connectors (light or abs)
Here is what I have from a 1993 Legacy Turbo Sedan. It was an auto but i believe this part is the same from auto and manual, might want to double check that tho. The 2 wires in the pic that are cut are for a diode related to the fuel system. a previous person replaced the burned up diode. The wires go to the back of the SMJ on the other side of the harness that goes to the firewall. This harness came from a running car I parted out to use the shortblock in my 22t/205 build. This harness has the square style engine connectors with 1 round engine connector.
Here are some pictures.
nortonjefferson
Bingo, that's just what I need. I believe it does not matter if it's from an auto or manual. I'll pm you tomorrow and maybe we can figure something out for next weekend? Thanks for pulling it out and taking good pictures!cj91legss wrote:Here is what I have from a 1993 Legacy Turbo Sedan. It was an auto but i believe this part is the same from auto and manual, might want to double check that tho. The 2 wires in the pic that are cut are for a diode related to the fuel system. a previous person replaced the burned up diode. The wires go to the back of the SMJ on the other side of the harness that goes to the firewall. This harness came from a running car I parted out to use the shortblock in my 22t/205 build. This harness has the square style engine connectors with 1 round engine connector.
Sounds good.
I've got a 91 I need to part out.
nortonjefferson
Sorry i didnt get back! i appreciate the reply, although i already aquired a front harness last week. i may need some other misc parts, ill PM you if i have anything i can think of! where are you located?Tatsturbo wrote:I've got a 91 I need to part out.
Pntaste4evr99
- Winestone Cowboy
Need an ECU?
I'm in burlington area...not too far away.
nortonjefferson
I actually plan on going the robtune 550 route with my build but i appreciate the offer! i still need a dp, boost gauge, blow off valve and a few other things. If you have any of those let me know!Pntaste4evr99 wrote:Need an ECU?
Oh perfect! ill stay in touch im sure ill need some turbo parts for my swap at some point here soonTatsturbo wrote:I'm in burlington area...not too far away.
