Summary of Modifications:
-Ej20g engine, rebuilt td05 turbo, STi injectors, Apexi intake, and custom exhaust. 287whp, passes emissions and can get 31 mpg hwy.
-Rebuilt Turbo legacy 5spd from a 91 Legacy Sports Sedan with exedy clutch, lightened flywheel, and Rear VLSD.
-AGX struts, Ground Control adjustable height sleeves with Eibach springs. The springs rates are around 2006 STi spec C rates with a little more in the rear to compensate for the wagon ass and heavy loads. I had it lowered for a while and then raised it for winter and never lowered it again.
-EDM glass headlights with city lights with clear vinyl cover.
-02 WRX seats. These go well with the black and gray interior of the touring wagons and are very supportive
-99 RS wheels. The car will come with your choice of re92a tires with 70% tread left or Hankook w409 studded snow tires with a season left on them. The hankooks have a slightly larger size wall.
Modifications:
Engine:
-ej20g with approximately 80,000 miles. Runs great with an engine reseal and new timing belt 5,000 miles ago.
-Yellow side feed STi 525cc injectors.
- Rebuilt TD05 16g from JDM GC8 STi. This has 3,000 miles on it since the rebuild.
-RobTune ECU. This ECU has been developed to allow the ej20g run properly on US pump gas. It is specific to the ej20g with TD05 turbo and USDM STI side feed injectors. Rob's dyno numbers with this car’s setup are 287whp and 257wtq. The optional extras include 7500rpm redline, launch control set to 4000rpm. This passes emissions with no problem. Below is a link to the tune details but you all know the details.
http://www.robtune.com/general.html
-02 WRX coil on plug retrofit.
-Apexi intake specific for the ej20g with pre-filter.
-Custom exhaust with high flow cat. Comes with a WRX bellmouth downpipe modified to work with the legacy’s o2 sensor and a stock WRX downpipe for emissions compliance which is currently installed. This exhaust sound great without being too loud.
-Walbro 255 fuel pump installed 3,000 miles ago.
-Prosport electronic boost gauge.
-prosport manual boost controller.
Transmission:
-91 Legacy Turbo 5spd rebuilt 13,000 miles ago.
-Exedy Stage 2 clutch with lightened flywheel.
-91 Legacy Sedan VLSD rear differential
Suspension:
-AGX struts with Ground Control sleeves and Eibach springs. The spring rates are GD STi Spec C. The rear rate is a little higher to handle better when the back is loaded up. I have the height set right at about stock. Great for deep snow or forest service roads.
-STi front strut top mounts.
Wheels/tires:
Exterior:
-EDM glass headlights with city lights imported from Poland. These headlights are amazing. Great cutoff and very bright with Osram +10 bulbs. I installed clear vinyl on them to protect the lens from gravel.
-Aluminum sump skid plate.
-JDM projector fog lights (not installed) with oem switch.
-mud flaps.
-Hella supertone horns
Interior:
-02 WRX seats in great condition.
-91 legacy radio with AUX input.
-Restored wood grain shift knob.
-04 STi e-brake handle.
-Prosport boost gauge.
-All weather floor mats
-All weather cargo area mat.
Extras:
-Invidia bellmouth downpipe.
-Many extra parts for these old turbo cars. Mafs, IACV, and more.
-Extra front grill
Every few hours I get a little off throttle knock detection flashing on the check engine light(a rob tune feature). I spoke to Rob and he believes it is not real knock but that either the knock sensor is going out or there is something causing false knock. The way I get around this is to let the car idle for a second and it goes away.
Price is $5,900 Cash.
And some older pictures
When it was low
