O2 sensor
tilidie19xx
O2 sensor
Post by tilidie19xx »
I have a 97 legacy outback and my second cat it all broke apart. If I cut it off and replace it with a straight pipe is that gonna **** with my O2 sensor? Or am I better off drilling a hole and welding a nut on the pipe I replace it with? I jus don't want car to run like butt
Sent from my SCH-I545 using Tapatalk
Re: O2 sensor
Welcome to the BBS.
Do you currently have a CEL? How do you know the second catalytic converter is broken apart?
You will need to keep the second O2 sensor there or you will get a CEL. So if you replace the second cat with a pipe you'll need to put an O2 sensor bung on that pipe so the second O2 sensor works.
