Fmic Coolant reservoir
tfoote3
Post by tfoote3 »
Im doing a fmic install and i bought the kit for the gc8 and flipped the cooler, and suprise. the oem coolant reservoir is in the way of the coldside pipe, ive got everything else sorted out hopefully. alot of cutting and welding. haha but in the end hopefully its worth it. I wanted to know from people who have had this issue what the solution was for them, ive contemplated cutting it and using fiberglass, but i wanted to know what others have done before i do anything irrational. any and all info is appriciated
Re: Fmic Coolant reservoir
I used something like this.
http://www.ebay.com/itm/Perrin-ASM-ENG- ... 1e&vxp=mtr
Not for 144 bucks tho.....
impostor
Post by impostor »
Also something to consider is the JDM reservoir. It sits inside the front of the fender and has a small neck in the engine bay. I'll try to snap a pic tomorrow.
dscoobydoo
Post by dscoobydoo »
I have a JDM reservoir. I can source one from Japan for you.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
Pntaste4evr99
Winestone Cowboy
Post by Pntaste4evr99 »
I moved my battery to the trunk.
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
robertpaige
Post by robertpaige »
You talking about the plastic coolant expansion tank? I used a skinny glass bottle, drilled a hole in the cap and secured it with a metal tie. It worked well. No pics unfortunately. Everything on these cars is so DIY. Haha
Had more Legacy's than I know what to do with...
Current: 92' SS
tfoote3
Post by tfoote3 »
robertpaige wrote:You talking about the plastic coolant expansion tank? I used a skinny glass bottle, drilled a hole in the cap and secured it with a metal tie. It worked well. No pics unfortunately. Everything on these cars is so DIY. Haha
Yeah, relocting the battery isnt the issue as i flipped the cooler so the piping isnt in the way of the battery. I was curious to see what others had done, I think I'm just going to slap something together
You can get the Weapon R tank. I plan to.
