I have looked at all the sticky threads, i'm 90% sure it will work with the a rob tune i'm just triple checking to be 100% sure before plunging in.
http://www.ebay.ca/itm/Jdm-Subaru-Legac ... T2&vxp=mtr
To triple check. Will this ecu work with a rob tune a ej22t?
SomeOldHobo
Re: To triple check. Will this ecu work with a rob tune a ej
If it's a WRX/STI ej20g ecu it'll work. The one in your link is for a legacy twin turbo. Also note that a Forester "ej20g" is actually an ej20k in all ways except the name, so their ecu will not work. Kind of confusing.
Additionally, prefacelift Legacy/liberty ej20g ecu's are only 8 bit and are not compatible with rob's tune, even though they have a space for his chip and everything.
There's a list of the correct ecus to purchase in the robtune thread.
That is a Hitachi ECU. It will not work for a Robtune. A Robtune needs a JECS ECU.
It's more than just a hitachi vs jecs thing - the twin turbos and other turbo engined subarus came with hitachi and jecs ecus, (example here: http://www.ebay.ca/itm/SUBARU-LEGACY-GT ... 0897819248)PhyrraM wrote:That is a Hitachi ECU. It will not work for a Robtune. A Robtune needs a JECS ECU.
Robs tune ONLY works with WRX or STI ej20g ecus. And those are made by jecs as you said.
SomeOldHobo
mike-tracy wrote:It's more than just a hitachi vs jecs thing - the twin turbos and other turbo engined subarus came with hitachi and jecs ecus, (example here: http://www.ebay.ca/itm/SUBARU-LEGACY-GT ... 0897819248)PhyrraM wrote:That is a Hitachi ECU. It will not work for a Robtune. A Robtune needs a JECS ECU.
K thanks that actually did help.
