First up is a front swaybar from a 2004 Legacy. It is 21mm in diameter, and is the largest OEM front swaybar available for the 1st through 3rd gen platforms. This is 1mm larger than stock for the 2000-2002 or 2nd gen GT, 2mm larger than stock for 2nd gen non-GT, and 3mm larger than stock for most 1st gens. For reference, the Whiteline bar is only 1mm larger than this bar.
There are no bushings included, just the bare bar. Whiteline makes some nice polyurethane bushings for about $20 depending on the bushing style your car needs. $50 plus shipping ($10-$20 depending on distance)
