crankshaft and camshaft sensor HELP !!
panxodh
Post by panxodh »
hello friends, I hope you are well.
as you know, I do not have a good English, so here I help you with pictures to explain better.
the engine is a ej20g 1994.. the wiring is a 1995 ej20g wrx...
This is the camshaft sensor plug:
and this is the plug wiring:
This is the crankshaft sensor plug:
my question is, as I do? You can join cables?
excuse my English, because it is bad.
if there is someone who speaks Spanish and can help me it would be good.
many thanks friends !!
panxodh
Re: crankshaft and camshaft sensor HELP !!
Post by panxodh »
If I understand correctly, you are trying to use the 94 ej20g crank & cam sensors, but the do not match up with the wiring from the 95 ej20g WRX. To make this work you would need to either find the wiring with the correct connectors and splice the wiring together or you could try and find a completely different plug with wiring and make it work.
