My speedo cable broke down in two pieces and I'm unable to find a replacement here in Brazil. Anyone know where I can get one online?
It's a 1993 Legacy Touring wagon 2.2 with 5MT.
The transmission end of the cable (kind of a screwdriver - see pic bellow) is still in there as I was unable to dettach the neck from the transmission. I'm planning on removing the transmission for a clutch job anyway and then deal with the speedo altogether.
For now, I got a intermitent check engine light and the engine hesitating occassionally for a quick sec.
Cheers
Wagonship: 1993 Legacy BF (High Roof Touring Wagon) EJ22 5-spd manual with low range \o/
Maybe I've found a way out. Some other cars cables are just alike. Bought one for less than $5 bucks. Now finally removed the metal neck from the transmission and will silver weld new cable + screwdriver-like end. Let's hope it works. Anyways, a link to a new cable is welcome.
cheers
Looks like the parts might be compatible between early 1st gen legacys and the earliest 1st gen imprezas as well. In case you have a junkyard nearby with imprezas or legacys.
Josh Colombo wrote: Mon Jan 14, 2002 10:23 am
Wait....I'm confused now.
