complete service manual for 93-94?
oldscoobyturbo
Post by oldscoobyturbo »
Hello everyone
I currently have a semi complete 89-92 service manual with the jdm info included.
I'm stuck having issues finding info for the later model airbag system as the older versions did not include it
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
Re: complete service manual for 93-94?
Unfortunately I don't have anything to help. One thing to note is that the model year split is different for the non-North American cars. The pre facelift cars were 89-90 and the post facelift cars were 91-93. Based on the info from Wikipedia, driver's side airbags were an option midway through the 1992 model year and became standard in 1993. So the info in the FSM is probably only going to be available in the 93 supplement, which may be quite difficult to find.
oldscoobyturbo
i figured as I have the same selection of fsm as you do. if I find it i will make sure to share
Ok, thanks! It'd be good to add it to the collective knowledge base if we can find it.
Alphius
Post by Alphius »
Ugh, I kick myself for getting rid of my FSM set when I got rid of my 94. Mint condition, never used in a shop full set of 91 FSMs with 92, 93 and 94 complete supplements.
Alphius
Post by Alphius »
Found a 93 and 94 supplement on eBay, if I remember correctly the 94 supplement was basically only the R134a A/C changes and maybe a couple other tiny things. 93 might have included the airbag info.
93:
http://www.ebay.com/itm/Subaru-Legacy-1 ... sO&vxp=mtr
94:
http://www.ebay.com/itm/Subaru-Legacy-1 ... tL&vxp=mtr
Also found a couple decent sets of full manuals from 91 and 92:
http://www.ebay.com/itm/1991-91-SUBARU- ... en&vxp=mtr
http://www.ebay.com/itm/1992-Subaru-Leg ... uV&vxp=mtr
JSkeezLegacy92
Post by JSkeezLegacy92 »
What is it that you are looking for for the airbags? Because I'm most likely looking for the same thing haha
I don't need it, but I'm tempted to get the 91 set so I'll have everything from 90-94
PhyrraM
Post by PhyrraM »
To add to the pool of knowledge....
'90, '91, '92 All have USDM fulls sets.
'91, '93, '94 Have USDM supplementals. The '91 supplimental adds turbo info and '90 > '91 changes.
I have managed to collect all the above. There may be more volumes out there that I haven't stumbled across.
Another interesting tid bit.....There seems to be both Japanese printed manuals (for USDM cars) and USA printed manuals. I have seen sets with slightly different coloring and page size and this seems t be the explanation.
If somebody has a not-so-time-consuming way of scanning a bound manual I'd gladly add them to the knowledge base.
I ended up picking up that 91 FSM set which came with the 91 supplement.
Yeah if there was less time-consuming way of scanning everything I'd do it to share the information.
