Air bag question
icrman
Air bag question
Post by icrman »
Does anyone know the squib resistance ? Like if someone has installed an aftermarket steering wheel and doesn't want the light on all the time.
Danny-G
Re: Air bag question
Post by Danny-G »
You can just unplug the light behind the cluster
Danny
Or remove the airbag computer
JSkeezLegacy92
Post by JSkeezLegacy92 »
When you take apart the cluster, behind the airbag plug is a little motherboard that is hidden behind a piece of plastic. That motherboard tells the car when to keep that airbag light on. You can just remove it completely or just don't plug in that connector that goes to it. It'll keep the light off that way. Even with the computer taken out and the wires cut, that little motherboard tells it when to go on
