O2 code 32
Phantomgoon
O2 code 32
Post by Phantomgoon »
I have recently installed a Bosch 4 wire oxygen sensor into my new o2 bung. The car runs fine but my O2 code 32 keeps popping up. I have a 1994 Subaru Legacy Turbo. Before installing this oxygen sensor my MPG was pretty low but now it's reasonable yet I'm still getting the code even though the oxygen sensor seems to be working. I've cleared the ecu code storage as well but it still comes back. I have replaced the spark plugs with ngk's as well. We put the new o2bung right behind a turbo pretty much where the stock one would be.
Austin
1994 Subaru Legacy SS
Re: O2 code 32
Hi Austin and welcome to the BBS.
Have you checked the resistance of the wiring coming from the O2 sensor to the ECU? If not, I'd suggest doing that. The other thing to note is that stock O2 sensor was only a 3-wire O2 sensor. The sensor grounded itself through the body of the sensor. The 4-wire has a separate ground wire that is used to ground the sensor. If that is going to an empty terminal then that's likely why you're still having issues. The best solution if you can do it would be to find a spare pin to put in the empty spot on the chassis side connector and then tie that wire to the O2 sensor heater ground circuit.
Ultimately that 4th wire likely just needs to be grounded, so however you do that...even if it's kind of crude would likely solve your issues.
Re: O2 code 32
Or....if you determine grounding the 4th wire does cause the light to go away then the easiest solution would be to see if you can return it and get a 3-wire sensor.
Phantomgoon
Re: O2 code 32
We wired a 3 wire and it made the car run horrible. We could have possibly had it wired wrong but from what we were reading it was wired right. I have it grounded with a bolt by the dog bone. But I could probably go pick up another three wire and see how that works, thanks for your help!
Austin
Re: O2 code 32
Ok, if you've got everything wired properly I'd double check the resistance of the wiring from the O2 sensor chassis plug back to the ECU.
