non turbo harness into a turbo questions
oldbugeye
Post by oldbugeye »
We are going to re wire a friends 93 turbo wagon and I have a few questions. I pulled the harness that goes through the firewall from a junkyard its a 93 non turbo harness. I know we have to run wires for the turbo sensors. On the turbo harness there is big white and grey connectors that are held together by bolts . And on the non turbo harness there is only the big grey one. What wires are on that white connector? It seems to have more wires than just the turbo sensors.
dscoobydoo
Re: non turbo harness into a turbo questions
Post by dscoobydoo »
Pretty sure the FSM has been linked in here. I would open it up and view the wiring diagram
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
dscoobydoo
You would be amazed at how many more wires the sensors for the turbo add
05 GD-STI
00- GF
Yeah, the turbo cars have a lot more wiring so unless you are going to eliminate other components I wouldn't recommend using the non-turbo harness.
