Legacy Wiring Connectors
dankberries
Post by dankberries »
Incomplete wiring connector parts reference. Specific to first generation 1990-1994 legacy.
The purpose of this thread is to assist in the search for connectors found on the first generation legacy. Listed below are parts numbers of each connector. If looking for new replacement connector(s) the parts numbers can be typed into Google and then further researched for purchase.
*In most instanceses it's not likely that a complete connector is in need of replacement, rather just the wiring lead from it. In which case you may rather replace the wire with a new terminal. Research terminal parts #'s.
*Note, many of the terminals are the same for multiple Connectors. Different part #'s exist for gold plated terminals, guage of wire, and seal size.
--Engine harness
Wasted spark coil pack 3 pin Connector:
Search parts#: 6180-3451
Wasted spark Coil pack female connector:
Search parts #: 6187-3801
____________________________________________________________________________________________
IAC valve 3 pin Connector:
Search parts #: 6189-0027
Coolant temperature sensor 2 pin brown connector:
Search parts#: 6189-0033
Canister Purge Control Solenoid 2 pin blue connector:
Search parts#: 6189-0031
Injectors 2 wire connector:
Search parts#: 6189-0035or Denso/Nippon injector connector
Denso/Nippon plug:
*Note that several manufacturers are making this plug, there are several variations, the plug I have listed is known to work with 91-94' turbo legacy pink injectors. Variations are found with guide/key way slots, be sure to match those correctly when purchasing.
*Denso, Nippon, Bosch, and Deatschwerks are just some of the known manufacturers
Throttle Position Sensor 4 Wire Connector:
Search parts #:
Engine Harness Ground Connector 8 wire:
Search parts#: 6187-8691
Engine Harness Ground 8 way Male Connector:
Search parts#: 6180-8451
Engine Harness 16 way Connector:
Search parts #: HM16-P, HM16-S, Sumitomo 16 way
Engine Harness 12 way Connector:
Search parts #: 99CK0012, sumitomo 12 way
Places I've found to purchase connectors:
eBay
amazon
corsa-technic
Ballenger Motorsports
MACS
Alibaba
**This is a work in progress, I have a bit more info to edit and add
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
Re: Legacy Wiring Connectors
Awesome work!
Just an FYI the round "Engine Harness Ground 8 way Connector" is only applicable to the turbo legacy. The 90 and some of the 91 non-turbo cars had all square connectors, then the 92-94 cars only had two square connectors.
