Maf causing robtune fuel cut at 6lbs?
chanley2010
Post by chanley2010 »
Whats up guys, having a hard accel loss or fuel cut at 6lbs of boost with the robtune, jecs maf, 550 injectors, etc
Changed the maf back to stock and car cut fuel at like 1 lbs of boost, ran the car without the maf on which allowed it to boost to 15 lbs but had a popping,backfiring sound coming from motor with accel loss.. anyone have an idea with this or possibly if there is a larger range maf voltage on other subarus?
marsh27
Re: Maf causing robtune fuel cut at 6lbs?
Post by marsh27 »
In for answer. Having similar issue
93 fwd beater wagon
93 tw build in progress
Alphius
Post by Alphius »
What's your spark plug gap?
wtdash
Post by wtdash »
So you didn't get a MAF code w/swapping MAFs? Car could run LEAN and blow up a piston>block>etc.
Not a good idea.
Try a different JECS/AUTECS - GREEN - label MAF only. They do fail.
No other MAFs are scaled to run w/the Robtune. Rob was looking into the Nissan MAFs - Z32, but I wouldn't hold your breath.
Unless you're running excessive PSI (or oversized turbo), it's not a MAF sizing issue.
Put the correct MAF on and check for Codes - after clearing the existing ones.
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
