NA with wrx clutch?
NA with wrx clutch?
I'm doing a 5mt swap in my 91 legacy LS out of a 93 legacy L and bought a 02-05 wrx clutch because I've seen around the forums people using them but only for turbo cars. So would a wrx clutch work with a NA? I have a ej22et
Re: NA with wrx clutch?
Won't work with an NA transmission. Has to do with the pressure plate and clutch fork working in the opposite directions between the "pull" and 'push" style transmissions.
