ECU location, I cant find it
WRXish
Ok guys, where is the ECU hidden on the ist gen cars? I cant find it
Re: ECU location, I cant find it
Remove the larger panel under the steering column. The ECU is to the left, held in place with two 10mm nuts.
WRXish
thank you Mike, I would have never found it, the manual I have shows it on the the passenger side in the floor but of course I didnt find it there.
