Cleared lenses
bcmaxx
Cleared lenses
Post by bcmaxx »
It is possible to clean these ole nasty fluted plastic lenses up!!!
Re: Cleared lenses
Looks good!
Just out of curiosity, what have you done to your corner lights?
bcmaxx
Re: Cleared lenses
Post by bcmaxx »
I defluted them also. Blacked the inside. But left the inner light diffuser so the bulb light would still be decent. I had to run a border because the glue seam is visible through the clear lenses now. Fluting hid it all stock
bcmaxx
Re: Cleared lenses
Post by bcmaxx »
Re: Cleared lenses
That looks really good man!
Re: Cleared lenses
Looks awesome, but how long did that freakin take!?
Re: Cleared lenses
Yeah it does look good, and I bet it took a long time ;)
dankberries
Re: Cleared lenses
Post by dankberries »
Can you share the process detailed in achieving the finished product?
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
ride_child
Re: Cleared lenses
Post by ride_child »
yes please!
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
bcmaxx
Re: Cleared lenses
Post by bcmaxx »
well the sanding process is 9/10s the work.
- lamps must be heated in an oven @ 225c for about 15 min each to melt the butyl sealer and carefully seperated.
-markers are especially difficult because they use 4 clips (lens connects positively to lens housing in 4 places) and mayor may not have 2 hidden screws per lamp that connect the lens to the housing.
- lenses now must be sanded free of inner fluting beginning at 80 grit, progressively working up incrementally to 1500 grit wetsanding ( 320 was last grit I dry sanded) while sanding you can stop, get the lens wet, and you will see flaws, or areas you need to work on)
- after wetsanding I 4 stage polished them inside and out with meguires heavy, med, fine cutter, machine glaze swirl remover/sealer, and hi gloss wax.
- proform pf410 butyl tape was used to reseal lenses- approx 220f for 7 to 10 min each for reassembly
-customization of housing, for me was simple, I just blacked out headlamps and marker lamps, BI-XENON: MORIMOTO MINI H1 7.0 are a direct fit and a high quality lamp!
Im sure im missing a few things, and i need to get my photo host account fixed for more pics!
Re: Cleared lenses
Just looked through your photos. Very nice work!
bcmaxx
Re: Cleared lenses
Post by bcmaxx »
Sanding polishing time was approx 26hrs . Had a setback with polishing. Must have got grit in a pad. Headlamps went from near completion. Back to 1500...uhhg. could do in under 20. But honestly....ill custom clean mount a rigid led bar before id do that again
bcmaxx
Re: Cleared lenses
Post by bcmaxx »
Ill update with pics if i can figure out my photobucket password...im about 3 email addys beyond when i signed up which doesnt help
