Gauge mounting 91 leggy
WRXish
I want to add gauges in my leggy wagon, looking for good mounting spots open to all ideas. Also, any ideas on good egt gauge package? Thanks in advance.
Re: Gauge mounting 91 leggy
Most people do an a-pillar mount or replace the center A/C vents with a plate for gauges.
I've also seen people put them down by the stereo, but I'm not a huge fan of that positioning.
Another decent option is a gauge cup attached to the steering column trim in front of the speedo or tach.
My current setup
93 fwd beater wagon
93 tw build in progress
WRXish
Alphius wrote:Most people do an a-pillar mount or replace the center A/C vents with a plate for gauges.
Is there someone who actually makes a good A-pillar mount for the first gen cars? I would be content to go that route to avoid hacking up the ever so necessary air conditioning outlets. The A-pillar mounts are fairly easy to work with if made properly.
If you do some searching, there's an early 90's Honda application that works almost perfectly in the firstgen Legacy. There aren't any direct-fit parts.
Pntaste4evr99
- Winestone Cowboy
I had good luck with a Nissan 240 A pillar shell a while ago
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
Alphius is correct. The early 90s civic and crx pods should work well
93 fwd beater wagon
WRXish
Alphius wrote:If you do some searching, there's an early 90's Honda application that works almost perfectly in the firstgen Legacy. There aren't any direct-fit parts.
Thanks for the info Alphius, I will look around and see what I can find...I am also considering trashing the ashtray and mounting the gauges there, I know its not ideal but its not a race car, so being in the line of sight is not as important. I can glance down at them at stoplights if I cant manage it any other time. zzzzzz
