Best choice for front wheel bearings
WRXish
Post by WRXish »
Its been barely a year and I'm going to have to replace front wheel bearings....again. I only want to do this once. What's the best choice for this?
Re: Best choice for front wheel bearings
From what I've heard the main issue with the bearings is not necessarily the bearing but how they're installed. Do you add grease, do you not add grease, etc. I don't know all the details, but know it's a contested issue.
In general I like the Japan-made bearings like NSK.
WRXish
Post by WRXish »
Thanks josh, picked up fwb at dealer today. 65 bucks roughly. Did not buy hub there, that was 150 for Subie brand part. Wonder how much of a press is needed to press bearing into place. Any idea?
I'm not sure about the press. I've never done it myself. Hopefully someone else can chime in.
Alphius
Post by Alphius »
I just did front wheel bearings on my wife's Outback, I have a 20-ton hydraulic press. Wouldn't want to do it with much smaller. Felt like it took a good 10-15 tons to press the old bearing shell out.
oldscoobyturbo
Post by oldscoobyturbo »
I change these all the time for many different subaru models. I use 20 ton press too. I use grease to install the new parts together. The most reliable brands are skf, nsk, fag
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
