I'm sure this has been covered but I cannot find it anywhere.
Can someone confirm how many injector o-rings go on the actual injector in this application. I am showing 2, one at the top and one at the pintle.
Thanks!
							550's into 93 NA Rails
High Speed Dirt?
						Re: 550's into 93 NA Rails
thats correct just the two o rings. You have to switch out the little rubber pieces in the injector caps as well if I remember correctlycamped69 wrote:I'm sure this has been covered but I cannot find it anywhere.
Thanks!
93 fwd beater wagon
93 tw build in progress
Are you just wanting to replace the O-rings or are you wanting to change O-rings to make them fit the rails?
You should be able to use the USDM 550 side feed injectors as a direct drop in to the 92-94 non-turbo rails.
Hi Josh. I just wanted confirmation on the number of O-rings needed for the install to work. Injectors came with 2 new O-rings.
Sent from my LG-D851 using Tapatalk
High Speed Dirt?
Ok, thanks.
