ride_child wrote:no the 20g engine was a coil on plug setup and is wired so at the ecu. the 22t is a wasted spark setup and is wired so at the ecu. in order to run the 20g ecu in our cars, we either have to convert to a coil on plug setup, which is the way the original modifier went since you have a 20g engine as well.
the other route is if you are still running a 22t in which case there are a few ways you can make an adapter to trick the ecu into thinking its running a coil on plug setup, but that doesnt matter for you since you have a 20g engine.
even though you have a 20g ecu and a 20g engine, unless the original modifier did a harness swap as well, you will still have to do some modifying on the stock 22t harness.
Ok...This post has a lot of information, that either has been noted already, or is useless. I know it was converted to GD WRX coils, I know the ECU is wired like it's a 4 channel...because that's what it is. My question is if anyone has seen this before, if so where, and if anyone knows why they would move the wires to the terminals they did when the ECU is supposedly 4 channel stock. They would normally be wired to 7-10 I believe, but they have been moved.
*Edit to explain further*
After reading again, you were just arguing my point about saying it should have been bolt in. What I meant was the wiring should have needed a lot less hacking than what was done, I've fixed and figured out 90% of it, this is the only part I don't understand.
