ej255 into a 93 legacy ss
trippywhitekid
When i got the engine into the engine bay the ej255 mounts arent close to the sub frame slot to bolt the engine mounts to the sub frame. was wondering if anyone had any info on what mounts or what i should do to get the engine to work
Re: ej255 into a 93 legacy ss
If they don't fit, you have them reversed left to right.
trippywhitekid
ok ill give that a shot and i shouldve specified im using the ej255 engine mounts from a 04 forester xt
It should go in fine. Engine mounts varied slightly over the years but the mounts on the engine, mounts in the subframe, and where they are supposed to be relative to eachother is the same for everything. So I guess you could have the mount backward on the plate.
peter@functionauto.com
