91 Legacy SS factory 5mt. $2300
Hello all. I am a long time member but cannot for the life of me remember my username and password. So I made a new account. I would love to see this car go to an enthusiast. Anyway onto the add.
I have owned this car since 2009 and I have loved it. I will try to be complete on the mods and build.
I bought it with 170,000 miles. at that time i did timing belt, all associated pulleys, water pump, and re-gasketed the oil pump, and front seal on the oil pump. I didn't know when it was last done.
later at about 210,000 I did the camshaft seals, rear main seal, oil pan rtv, and I pulled the trans and re-did the clutch and pressure plate and throw out bearing, with an exedy wrx stock clutch kit. unfortunately under the advice of my mechanic I did not resurface the flywheel. He said it didn't need it.
I also replaced fluid in the trans and diff with redline fluids. that same time. as well as valve cover gaskets.
Currently there is 260,000 miles on it. and it will not go up as I have not been driving it for a few months now.
currently this is the only add I have up right now.
1991 Legacy Turbo. Factory 5 speed. 3.9 Final drive, viscous LSD
a List of modifications that i can remember:
A complete 1994 SS interior, mainly seats and door cards. but random console and dash pieces.
Dyed black carpet
aftermarket stereo
homebrew short shifter
LED red dash lights.
Tinted windows, 20 percent rear 5 windows, 50 percent front 2
front and rear WRX brakes and rotors. painted calipers and brackets.
drilled and slotted rear rotors.
Just replaced front rotors and ceramic pads(sorry didnt splurge on the drilled and slotted fronts.)
stainless steel brake lines front and rear
wrx master and slave clutch cylinder.
TD04 turbo
2004 STI blow off valve
2006 WRX intercooler
wrx silicon y pipe kit
my own version of coffee can mod
exhaust gaskets all replaced with MLS gaskets
intake manifold gaskets replaced
sunroof has been resealed
trunk carpet was replaced because it was stained
walbro 255 LPH fuel pump
new fuel pump relay and stock fuel pump wiring harness
2 front cv axles at about 230,000
wrx stock shocks front and rear
Prodrive lowering springs
tires only have about 8,000 or 10,000 miles
17 inch MB wheels. i believe they're called MB 7X
rear suspension has all been gone through and rusted parts replaced
rear lateral links have been swapped for the more modern ones to run wrx sway bars
nothing on the rear end is seized
custom grille
the Bad:
A/C was deleted. by me, I was only 18 at the time so I thought i didnt need it.
there is quite a bit of rust. mainly on the rear quarter panels.
I bought it with the big dent on the drive rear quarter
no rear speakers. just the front two are installed
sun roof stopped working this year. it's been resealed by me so it doesnt leak. but doesnt open either. probaby the relay unit
the roof was plasti-dipped by me a few years ago. needs to be removed
power steering has a slow leak.
headlights need to be cleared.
all in all its just starting to show its age.
but it is a good running vehicle. a few years ago it would make a couple trips up to seattle every year.
I would not hesitate to drive it across the country.
Located in Salt Lake city Utah. Willing to negotiate .
Pictures.
