Robtune with stuck launch control
Kamo_5
Post by Kamo_5 »
I have a 1991 legacy LS and I did a NA/T build and I also got a robtune love the tune so far except my launch control is stuck on at any speed and I can't figure it out. It's a 5mt swap with everything done correctly with the neutral switch,reverse lights and starter interlock relay wired up. I've looked through the forum and found a couple threads and I've done everything they said to do from sensors to the speedocable I would really like to figure this out. I have also contacted rob but he has not responded yet. Let me know if you guys have any ideas. Thanks.
Re: Robtune with stuck launch control
Did you ever get this resolved?
