Couple sets of heads, couple 2.0 blocks, steering racks, misc engine stuff....
Heads #.
bare, needs 1 valve seat replaced, spark plug cracks that aren't too bad (I've ran heads with worse.) These would be a good start to someone that wants to build a set of heads. I was going to use them on the recent project I finished but it was getting too expensive so the project went a different route.
$200 obo
Heads #2.
This is more of a disappointment than anything.
No plug cracks, some crazy invisible cam sensor sensor sorcery, Needs machining, and has mix matched cam caps.... basically a lot of work but has a valve train. I wouldn't have bought them had I noticed the cap numbers being wrong.
$100 obo
I have a couple 2.0 blocks. Both have knocks, need rebuilt. 1 has heads off so easy to check out, other I have to take the heads off, should be done soon though.
$250 obo each
22e block with 4 extra pistons. Missing one. Cylinder 4 dropped a valve and put a hole. Tiny little ding in the cylinder wall. Might need bored.
$100 obo
Couple steering racks from bugeys. 1 leaks, other has a bent inner tie rod.
$100 obo each
Some radiator fans. I got 2 pair 1 pair needs the plugs replaced. The wiring and pins are there just not the correct plugs.
$60 a pair
Any further questions, please pm!
2.0l bug eye stuff
2.0l bug eye stuff
