EDM glass headlights for '92-'94 Legacy (Post-facelift) - $175 (Tigard, OR local pickup or + shipping)
Post facelift EDM glass headlights for '92-'94 Legacy. Both left and right work perfectly-- including vertical and horizontal manual adjusters. Includes untested motorized vertical adjusters.
Left side was damaged when previous owner got it. The horizontal adjustment was broken and the reflector was loose inside the headlight. Someone had tried to use a drywall screw to hold the reflector in place. PO disassembled the light, repaired the pivot point and reassembled. PO broke off a rusted screw taking apart the horizontal adjustor, but after repairing the gear inside it works great.
Everything works normally on this light-- remaining damage from the original owner's drywall screw does not interfere with proper function. It's solid, functional, and adjustable in both vertical and horizontal directions.
These glass EDM headlights often go for over $300, these are a steal. I can't fit them on my Legacy as my intercooler required relocation of the stock headlights and there is no longer room for the adjustment hardware on the EDM lights to exist in my engine bay, so I'm selling them instead and keeping my USDM plastic headlights
Right side is in great condition with a repaired horizontal adjuster gear.
