Fwd fuse???
paulieearnhardt
Fwd fuse???
Post by paulieearnhardt »
So I'm new to Subaru. I just bought a 1999 Legacy Outback and I was poking around under the hood and I found this little Port that looks like a fuse goes in it. Tell me someone please what size should be in there and what it's for and if it's necessary please.
//uploads.tapatalk-cdn.com/201710 ... 73817f.jpg
//uploads.tapatalk-cdn.com/201710 ... 26cefa.jpg
Sent from my Z982 using Tapatalk
Re: Fwd fuse???
It's for use while being towed, not necessary or recommend for normal driving. You can put a 10+ amp fuse in there. You won't really notice a difference in fuel economy since the autos are 90% front wheel drive under normal circumstances. Handling will be compromised.
paulieearnhardt
Re: Fwd fuse???
mike-tracy wrote:It's for use while being towed, not necessary or recommend for normal driving. You can put a 10+ amp fuse in there. You won't really notice a difference in fuel economy since the autos are 90% front wheel drive under normal circumstances. Handling will be compromised.
Cool thanks alot man. Ill just leave it alone then.
