For sale engine and cooling system parts from a 94 Legacy SS with around 225 thousand miles on it. The car was running when the engine was removed and disassembled.
* EJ22T Pistons, wrist pins and connecting rods: (pistons have scuffing on sides, and need new rings, connecting rods need new bearings otherwise undamaged) $30
* EJ22T crankshaft (within factory specs but wear is evident on crankshaft pins and journals) $50
* EJ22T SOHC heads (one head was dropped and has a cracked timing pulley otherwise I believe these to be in serviceable condition) $50/head $75 for both
* EJ22T OEM radiator (originaly from 94 and rusted but it was holding pressure and keeping the car cool) free if you come get it (or the cost of shipping it)
PM pictures.
FS (Bellevue WA): Legacy SS stock engine parts
Re: FS (Bellevue WA): Legacy SS stock engine parts
90 degree elbow?
Do you have the intake manifold harness still?
The turbo I have (VF-22) has a 90 degree bend and I am keeping the silicon knee that came with it (not sure if that was an OEM part anyway). I have the stock intake manifold harness but I am pretty sure I need to keep that for my car to run. I am swapping intakes (to an EJ25D intake) but to my knowledge I need to use the old harness as the wiring is different between the EJ22T and EJ25D.
You will need the original harness with the new intake manifold. You must have bought that vf22 from Taylor. Nice guy.
