hello all,
any instructions on how to remove the headlights off a 91 legacy? thanks in advance
how to remove headlights?
Re: how to remove headlights?
You'll need to remove the grill and corner marker lights to expose the bolts that hold the lights in. Also, there are one or two studs going through to the engine bay with 10mm nuts on them. The lower nuts are hard to reach, and I unbolted the horns to get to em
