I have a 91 wagon. Limp mode
krkchrs
Post by krkchrs »
My automatic trans is stuck in limp mode. I can find any Info other that the handshake. My car will not do the handshake. I've looked everywhere on the web for a good electrical diagram to show me what powers the tcm and where the ecm comes in. I can find it.. looking for help!!! Please and thank you.. Image
Sent from my SAMSUNG-SM-G935A using Tapatalk
Re: I have a 91 wagon. Limp mode
Welcome to the BBS.
These are the wiring diagrams for the 90 Legacy, but should be same/similar for the 91 model year.
https://main.experiencetherave.com/suba ... agrams.zip
Those should help with diagnostic work. My first question would be, does the power light come on at all when the ignition key is turned from off to the "ON" position? If not, the TCM is not getting power and that's where you should start.
krkchrs
Post by krkchrs »
Thank you for this. I found a 92 and it got me far enough to rule out mist stuff. I found a cheap tcm and replaced it and that did the trick.
Glad to hear you got it taken care of!
krkchrs
Post by krkchrs »
Legacy777 wrote:Glad to hear you got it taken care of!
Thanks boss
