So I’ve got some squealing in the front driver brakes when I’m reversing, so I’m looking into some new front brakes. Just looking for a second opinion from someone with more experience so I don’t end up ordering the wrong parts, as it’s
my daily driver. Just need to know if these pads and rotors are A, compatible together and B, compatible with my 94 turbo wagon.
https://www.tirerack.com/brakes/brakes. ... toModClar=
						Are these compatible?
Re: Are these compatible?
They should be compatible based on the vehicle selection from Tirerack.
Squealing brakes could just be vibration of the pad in the caliper. Have you looked at the pads to confirm they are worn?
