Coil on plug conversion for robtune
Bcaron1000
Post by Bcaron1000 »
So I had a robtune in my firstgen and I have upgraded heads like most of you have done. I had problems with the ignition converter and my igniter kept blowing out. I figured out a way to make a small patch harness to put coil on plugs and eliminate my ignition converter along with my igniter. If anyone is interested il be selling harnesses for 50$. It also works great for the 20k coil on conversion. Let me know if you’re interested
Re: Coil on plug conversion for robtune
Moving this to the parts shed.
