Atmospheric pressure sensor?? ej22t 93 legacy
Legacyofmatt
Post by Legacyofmatt »
having much trouble locating the atmospheric pressure sensor for an ej22t found in 1st gen legacys. located on the pass side strut tower with vaccum lines going to it, should be looped into a second sensor near it .
would compensate you for shipping to me, Fredericton, New Brunswick
Re: Atmospheric pressure sensor?? ej22t 93 legacy
There is no atmospheric pressure sensor. You just have the MAP sensor which measures engine vacuum/boost and the pressure exchange solenoid switches over to read atmospheric pressure.
So are you wanting the MAP sensor?
Legacyofmatt
yes i figured it was just a map sensor as it resembles one, the ecu names the code atmospheric pressure sensor or turbo pressure sensor, which im assuming would be a map sensor either way. throws code 45 an runs 7psi after it happens
Legacyofmatt
it would be ideal if i could get a hold of both switching solenoid and map
Sorry if I made it sound like I had a MAP sensor.
Hopefully, someone else has one they are willing to part with.
Actually....I just remembered I may have one.
Let me take a look this week and see if I can find it. I haven't really been in the garage much the past several months so I need to do some looking.
