MILEAGE: 266k
At 190k, I replaced the clutch and timing belt / tb accessories.
It has newer CV axles, front wheel bearings & ball joints.
Alternator replaced around 230k and just did the valve cover gaskets about 18 months ago.
Comes equipped with WRX front and back seats, as well as WRX struts, springs and wheels.
New rear tires 6 months ago, fronts still at about 50% tread.
Both rear quarters have some rust, per usual. As well as some odds and ends places. I did a quick (very unprofessional) bondo job on the quarters as the sight of the rust was killing me. It's okay.
Interior (outside of the seats) is a little tired as you'll see in the pictures.
Mechanically, it does about everything you need it to. All (4) power windows work, power mirrors.
NO A/C.
Still leaks a bit of oil (maybe a few drops a day)
Exhaust has some rust holes throughout which give it a very deep rumble. Not obnoxious so I've never replaced.
Last tank of gas netted me right around 28mpg and that's primarily city driving.
Would like to get $1100 for it.
