01 Outback automatic transmission options?
greg donovan
Post by greg donovan »
What other cars can I pull replacement transmissions from?
All I know about mine is it's a 4.44.
Will a trans with the last 4 digits cdba work? It's from either a 01 OB or a GT seller isn't 100% sure.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
wtdash
Re: 01 Outback automatic transmission options?
Post by wtdash »
Ask over on https://www.ultimatesubaru.org/forum/ too, but if you use car-part.com it'll show you a cross-reference.
Remember, that in '01+ the OB had the H6 as an option, which had a different trans - VDC/VTD - I believe. It might 'fit' but the electronics may not work w/yours...if yours is the 2.5.
And does the 'cdba' match yours??
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
