Best $12 I've spent in a long time!
Got a new part? Is it the best thing you've ever seen? Is it a complete ripoff? Let us know about your parts and service.
Coyote
Post by Coyote »
If you've ever pulled or replaced the radio in the center console, you'll remember the 2 screws on the side of the mounting that are way back in there, in a narrow space. You have to put them in AFTER the radio and bracket is in and they are a stone bitch to get started without dropping them and the washers only make it worse. Drop one and you'll recall every cuss word you ever knew. . .
This tool cost me around $12 at my local Sears and I'd have gladly spent twice that because it makes the job dead easy.
I've seen them on Amazon too for about the same if you include shipping.
https://www.sears.com/greenlee-screw-ho ... 03271000P#
Any 20 minute job is only one broken bolt away from a three day disaster. . .
Re: Best $12 I've spent in a long time!
That's pretty cool! I guess it's a bit more solid then a magnetic tipped screwdriver.
Coyote
Post by Coyote »
Not only much more solid and secure, it works on brass screws as well. . .
