WRX Dash Install
nc_0utlaw
WRX Dash Install
Post by nc_0utlaw »
Hello all! New to the forum and new to being a Legacy owner. Experienced swapper with quite a few STI/WRX GC swaps under my belt. Current project is a 94 Legacy Wagon that I'm attempting a full WRX swap on and I'm wondering if anyone knows what exactly is needed to use the WRX dash in the BF. I know most everything mechanically will be plug and play but I noticed today when I stripped the car out that the dash bar is very different. I have used the search and searched the web quite a bit and while the topic is mentioned, nothing I've found has gone into detail. Any info you guys could provide would be greatly appreciated. Thanks!
Re: WRX Dash Install
Welcome to the BBS.
You'll want to talk to cj91legss. He did this swap and can give you a lot of feedback/info. I'd suggest checking out his build thread as a first starting point.
viewtopic.php?f=25&t=41769
nc_0utlaw
Post by nc_0utlaw »
Thanks! Thats gonna be a huge help!
It's quite a bit of a task for sure. You'll probably figure it out quicker than I did. It was my first dash swap ever.
One thing I did not do is use the full bar from the wrx. I just used the stock legacy half bar. This is a big mistake. I have the full bar to install sometime soon.
Reichenbach
Post by Reichenbach »
cj91legss wrote: Wed Oct 17, 2018 2:27 pm It's quite a bit of a task for sure. You'll probably use these affordable payday loans and figure it out quicker than I did. It was my first dash swap ever.
Oh so the full bar from the WRX fits? That's good to know!
