Anybody have a radiator for an EJ20G not sure if it matters but it’s AWIC. Mine cracked and I need a replacement ASAP. Or if anyone knows of any aftermarket one that will fit that’d be perfect aswell. Thanks guys
EJ20G radiator
JimBos Legacy
EJ20G radiator
JimBo
1992 JDM Subaru Legacy GT wagon
carfreak85
Re: EJ20G radiator
Location?
1975 Superstar Wagon
1984 GL-10 Turbo-Traction Wagon & Hardtop
1987 & '87.5 RX coupes
1987 RX Type-RA
2002 WRX sedan
2019 Outback 2.5i Limited
1987 RX Type-RA
2002 WRX sedan
JimBos Legacy
Re: EJ20G radiator
Houston TXcarfreak85 wrote:Location?
JimBo
Re: EJ20G radiator
The ej20g radiator in your legacy is interchangeable with an ej22t radiator (all years) as well as version 1&2 WRX/STI. You'll need to reuse your fans and that coolant tube that runs along the upper portion, no matter which radiator you end up using.
JimBos Legacy
Re: EJ20G radiator
That’s helps a lot, thanks mike, found a mishimoto all aluminum radiator that looks like it’ll bolt right up.mike-tracy wrote:The ej20g radiator in your legacy is interchangeable with an ej22t radiator (all years) as well as version 1&2 WRX/STI. You'll need to reuse your fans and that coolant tube that runs along the upper portion, no matter which radiator you end up using.
JimBo
Re: EJ20G radiator
Just to be clear, is the engine radiator you're looking for or the AWIC radiator?
If it's the engine radiator I will move this to the engine forum.
JimBos Legacy
Re: EJ20G radiator
I’m looking for the engine radiator, feel free to move it!Legacy777 wrote:Just to be clear, is the engine radiator you're looking for or the AWIC radiator?
JimBo
