WD 40 for iac?
jefferson
WD 40 for iac?
Post by jefferson »
I see a lot about seafoam to clean the iac, but what do you guys think of just using wd-40? It is an awful good cleaner and I have a lot of it. Interested to see what people have to say.
ronemus
Re: WD 40 for iac?
Post by ronemus »
I usually use carburetor cleaner - Gum Out or similar - followed by WD-40 as lube.
carfreak85
Re: WD 40 for iac?
Post by carfreak85 »
Brake clean for me, doesn't leave any residue. WD40 isn't really a cleaner or penetrating fluid, but it does those things adequately.
1975 Superstar Wagon
1984 GL-10 Turbo-Traction Wagon & Hardtop
1987 & '87.5 RX coupes
1987 RX Type-RA
2002 WRX sedan
2019 Outback 2.5i Limited
Re: WD 40 for iac?
carfreak85 wrote:Brake clean for me, doesn't leave any residue. WD40 isn't really a cleaner or penetrating fluid, but it does those things adequately.
Brake clean does leave a residue.
Maf cleaner or electrical parts cleaner does not.
carfreak85
Re: WD 40 for iac?
http://knowhow.napaonline.com/brake-cle ... e-without/
"Brake cleaner is made up of chemical compounds that evaporate as they dry, leaving no residue behind and dissolving grease for perfectly clean brakes...."
1987 RX Type-RA
2002 WRX sedan
