No start issue traced to ECU---do you have a spare?
WRXish
Post by WRXish »
Ok, I have a 2.5 running NA in a 91 wagon...the 92 ECU I had went up in smoke and I am having a devil of a time finding a replacement. The part number is a 22611 AA931F and it is no longer available through the dealer and I sent it off to have it tested and repaired to this place called module experts in Jacksonville FL and they said it was unrepairable. Does anyone have one of these laying around they dont want or need...or do you have a resource that I can use to get one? Any help at all would be greatly appreciated. The car has been out of service for nearly 8 months while I troubleshooted this problem. I need to get it running and out of my garage. Many thanks in advance for your help.
Bcaron1000
Re: No start issue traced to ECU---do you have a spare?
Post by Bcaron1000 »
I have a turbo legacy ecu from a 92...
WRXish
Post by WRXish »
is it the same part number as what I posted above?
Bcaron1000
Not too sure, I know there’s a 1990 Na first gen in the junkyard here I could pull for you
WRXish
Post by WRXish »
id be grateful to have a backup for emergencies at the very least.
A 1990 N/A and turbo ej22t ecu are both Hitachi's, and won't work with a 1992 JECS-ecu'd car.
nortonjefferson
Post by nortonjefferson »
I have a working hitachi ecu from a 91 sedan kicking around as well, if you still need it
White 1993 L Wagon AWD 5MT-FXT lift, 27” MTs 380xxx miles
White 1991 L sedan AWD 5MT-(Robtune 550 DOHC Ej22t swap coming together) 187xxx miles
Black 2005 LGT 5MT-Ej20x swapped daily, VF40/elh
He needs a JECS ecu
I might have some JECS ECU's, however am not sure if it would be that specific part number.
I'll try and remember to check tonight.
All I have is my 90 AT JECS ECU. It's part # is 22611AA382.
