Air Condition oil?
icrman
Air Condition oil?
Post by icrman »
So for 134 I guess pag 100 is what to use? The rebuild compressor came with something like pag 45 or 50 don't remember for sure. So do I leave that, or do I drain it and use pag 100 in the compressor before installing it?
The pag # is the viscosity I think, so I would think drain the thicker stuff out?
Re: Air Condition oil?
I used PAG 100, and yes the number refers to the viscosity.
I drained the oil from the compressor and put new PAG 100 in when I did my conversion. I had read somewhere in the past year or two about someone using something other than PAG 100, but I don't recall the details.
This was the post I was thinking of. I guess use the information as you see fit. I'd still likely use PAG 100.
viewtopic.php?p=451698#p451698
Omega79
Post by Omega79 »
There is an additive you can add along with the PAG100 as well... trying to remember the name and brand. Something like ICE32, works really really well.
lucas wrote:There were multiple Legacys with 300k+ miles. Jesus will return on a Turbo Lego.
I'm not too fond of additives, but I guess they have their place.
icrman
Post by icrman »
The shop that did the conversion said he uses PAG 100 and I have seen other info on using that in the old subaru's. So that is what I will use.
I've taken out all the ac stuff and done a good flush, and since it is not recommended to flush the compressor its likely best to just replace with a rebuilt one. I just wish the rebuilder for the compressor would not add the oil. The link did not work.
icrman wrote: Tue May 21, 2019 2:05 am The link did not work.
Are you saying the link I posted above didn't work?
If so, try it again. We're still working out some issues with the software.
