Jonah's 1993 Subaru legacy LSI
meatball671
Post by meatball671 »
Hey everyone, havn't posted to this forum in a while, but we recently came across a neat legacy that I thought would be worthy of it's own build thread. To start off the car is a 1993 Subaru legacy LSI wagon with tan paint and tan leather interior. The car also came with the airshock system. Everything was in the car except for the air struts. I'm assuming everything would work, but were going to be taking it out of the car.
One thing I noticed was that it looks like they used alot more seam sealer in the car idk kinda wierd, also the paint on the car was in pretty good shape.
When we bought the car it ran and drove great. The previous owner took pretty good care of it, the car was his daily driver.
So my brother had a 05 Forester xt that was rusting pretty bad, so we decided to take the engine from the fozzy and put it in the legacy with a 5 speed. My bro plans to refresh the engine, and do some minor mods to it. IWIRE is going to do the harness merge so everything will be pretty much plug and play, they also sell a DBW pedal adapter so it can bolt in to the legacy.
First we cleaned the enigne bay, so we could cut the holes for the clutch master and install the non-abs brake lines. We had to drill new holes for the bracket that goes to the rear, these brake lines are from an impreza but they fit pretty well.
One other thing to note was that the ecu looks alot like a ej20g ecu, So I guess anyone with a robtune could use a n/a ecu case. I thought that was kinda cool lol.
So that's pretty much where were at now, gotta send the harness's to iwire to get merged, and start doing some mods to the engine. I also ordered a quarter panel from Subie Savers, so that should help with the rust repair. Can't wait to see this thing on the road, and thanks for taking a look at our new project. :D
Jonah
92 legacy wagon N/A 5MT
93 legacy sedan 25th anniversary edition 02 wrx swap ver 2 jdm 5MT
93 legacy TW 25th anniversary edition 4EAT stock with supporting mods
94 legacy TW 4EAT built ej22t vf-34 CES exhuast
Re: Meatball671's 1993 Subaru legacy LSI
Jonah,
Looks like a fun project!
It does look like there is a bit more seam sealer on this car....
The other thing I'd suggest is removing the damper from the clutch master cylinder. I did not like how the clutch felt on my 2007 Impreza which had the damper in the master cylinder. It can be replaced with a drain plug bolt. I'd suggest doing that...you may need to take the clutch master cylinder out again to do this, but it's well worth the effort IMO.
This tutorial is pretty good and tells you what you need. I found that there was no additional damper in the slave cylinder so you likely don't need to do anything with the slave, just the master.
https://legacygt.com/forums/showthread. ... 40977.html
originalcyn
Post by originalcyn »
oooo exciting. Congrats.
Kijan
1993 Legacy LS | PBM 227
meatball671
Thanks for the tip Josh.
Jonah
meatball671
The panel from subie savers came in, and we started working on the rust repair. The quality of the panel is great, and it was easy to weld.
Jonah
That looks like a pretty good replacement fender! Definitely take good pictures.
meatball671
Re: Jonah's 1993 Subaru legacy LSI
Today we mocked up the new koyorad radiator. The radiator sticks a inch and half to tall, so we modified the bottom mounting plate to fix the height issue. We cut the top of the bottom rad support and welded new peices in, and used seam sealer.
Jonah
Looks good!
Fun stuff. This is kind of a unique swap. I haven't seen a Forester swap into a 1st Gen yet.
I second the clutch damper delete. On my SS, I just removed the damper and ran an SS braided hose in its place.
meatball671
Sorry for not posting in awhile, I hope everyone is doing well during this time. We got the harness back from IWIre, and they always do an excellent job merging the harnesses. Everything was high quality and went right back where it was suppose to. We also got the engine buttoned up with the TGV deletes and few other misc. things, but so far everything is going back together smooth.
New oil feed lines for the turbo and AVCS
This is where we mounted the fuel pump controller, we had to modify the mounting bracket to make it fit under the dash
We had to cut a hole in the grommet going through the driver side fender to fit the harness for the engine plugs
The harness pretty much mounted the same way in the engine bay, just had to run the connectors for the turbo engine sensors
This is the drive by wire pedal adapter that IWIRE makes everything bolted up with no problems
So the way iwire did the harness was they got a jdm harness for a ej255 and merged it with the legacy harness so the plugs would stay in the same location. they offered the option to put the ecu in the passenger foot well, but we opted to keep the factory routing
We also had to make the ej255 ecu fit in the factory location, so we took the mounting tabs from a n/a legacy ecu and welded them onto the ej255 ecu case, it's not the prettiest thing but it works.
we made the boost controller bracket fit to the first gen
We were able to get the dash back in the car today as well
Jonah
That is awesome work! I love how everything more or less fits back into the right spot.
If I do another swap I'll have to consider using their services. Do you mind how much they charge to do this?
meatball671
I think it was around $1,500. The Legacy harness is definently more on the expensive side. They had to source a jdm harness which i think was $400, but it really all depends on what engine and trans you're swapping in, and all the other options you want to put in. I think it was around$850 to do my impreza. Just a fyi i guess subaru stopped making the cable style speedo replacement piece that goes into the trans. We were unable to find one. If you are gonna do a swap have them do a cluster swap, so you can use the newer style vss. But yeah iwire can basically do anything you want them to.
Sent from my SM-G965U using Tapatalk
Jonah
Thanks for the info and heads up!
Urabus93ss
Post by Urabus93ss »
How did you go about wiring in the fuel pump controller? Have any pics from that?
meatball671
Sorry for not keeping this build thread updated, I've been super lazy with taking pictures and documenting stuff. To answer your question Iwire does all the the wiring for the fuel pump, you just have to run a wire to the fuel pump harness ground under the back seat. I was thinking about making a video about the car and where it's at, but the car is finished, I just never documented anything.
Jonah
meatball671
Here's a video, kinda giving an update on the build https://www.youtube.com/watch?v=dPmKQcrIeAs
Jonah
aredub2
Post by aredub2 »
So awesome.
adema2626
Post by adema2626 »
Any updates?
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
