DIY RHD Power Steering Lines
Sublimejoe
Post by Sublimejoe »
Ok, so there are a few threads around that serve as a walk through to make your own power steering lines, however none of them are RHD specific. Figured I would write this up so people can avoid buying the wrong shit three times like I did.
This is the thread I originally found, which has a ton of great info, but really only applies to LHD cars:
https://www.rs25.com/forums/f105/t18508 ... lines.html
It seems there are at least a few ways to do this. Using this setup requires you to use a rubber hose between the rack & pump for low pressure line.
On my setup I eliminated the hose barbed fitting on the rack side, and instead had a shop make me a rubber hose that had no fitting on one end, and a -6 AN female fitting on the other end. I haven't been able to find an 'off the shelf' option for that hose. Maybe I can update later if someone sees one.
Fitting Sizes:
Rack High Pressure - Male 14mm x 1.5
Rack Low Pressure - Male 16mm x 1.5
Pump High Pressure - Male 14mm x 1.5
Pump Low Pressure - 3/8" Barb
Fittings Needed:
Rack High Pressure - Male 14mm x 1.5 to male -6n https://www.summitracing.com/parts/ear- ... /overview/ $8.97
Rack Low Pressure - Male 16mm x 1.5 to male -6n https://www.summitracing.com/parts/ear- ... /overview/ $8.97
Female -6 AN to 3/8" Barb https://www.summitracing.com/parts/sum- ... /overview/ $4.99
Pump High Pressure - Male 14x1.5 to -6n male https://www.summitracing.com/parts/ear- ... /overview/ $8.97
Hoses Needed:
Pump to Rack (High Pressure) - 42" female -6n to female -6n https://www.summitracing.com/parts/fra-372042/overview/
Pump to Rack (Low Pressure) - 3/8" rubber hose https://www.summitracing.com/parts/fra-733006/overview/
Low Pressure Line; Rack Side
High Pressure Line; Rack Side
High Pressure Line; Pump Side
High Pressure Pump to Rack:
Low Pressure Pump to Rack:
My setup:
Parts Needed:
Manual Cluster
Front & Rear bumper Chrome Trim
Re: DIY RHD Power Steering Lines
Thanks for sharing Joe!
Can you get some more pictures to share. I will add this thread to the sticky compilation thread.
Sublimejoe
Yessir! I will compile and label the photos I have, then get them uploaded.
Also, I’m happy to report the lines work perfect and don’t even whine!
Parts Needed:
Manual Cluster
Sublimejoe wrote: Mon Sep 30, 2019 5:59 pm Also, I’m happy to report the lines work perfect and don’t even whine!
Awesome! Another win for the good guys! :lol:
