I know it has been a while since i have posted but im trying to clear some stuff out. maybe some of it will be useful to some of you guys.
3.90 open
3.90 vlsd
4.11 open
4.44 with on 06 wrx lsd. Needs to be shimmed properly.
60 for the opens each and 200 for either lsd.
2006-2007 Impreza wrx Intake manifold complete minus fuel injectors. All sensors are there and in working order. 300
2006-2007 wrx top mount cut to fit for an ej205 intake manifold comes with y pipe kit and BPV. 100
2006-2007 Impreza wrx ej255 heads. Unknown mileage came from a rod knock. 300
25d dohc timing covers whole set. 100
Other partial 25d timing covera 20 ea
Dual cam tensioner with bracket 12k 20
25d cam gears 2 sets with bolts 100 each. 1 has a small chip but still fine to run.
251 cam gears 50
Passenger impreza sedan tail light 40
2gen legacy sedan center light 30
25d intake manifold complete. 50
2gen headlights need wet sanded 50
15 sti front axles 150 ea
15 sti seat mounts/brackets 40
4.44 2gen diff with 06-07 wrx lsd. Need to check the lash/re shim it. 150
Ej255 has knock 400
OEM TURBO heat shield all 3 pieces 30
Everything is OBO text is best, Ask for pics!
CJ 253 332 8158
Some garage clearing...
Re: Some garage clearing...
What's up?
Adding some boost sensors i pulled from a junk yard car, a single din pocket with the flip up door as well.
