Looking for 93-01 GC8 steering rack rebuild kit.
Need to find a seal kit for the year GC8 above. I bought one to put in my car but while I have it out I’d like to rebuild it for ease of mind.
JimBo
1992 JDM Subaru Legacy GT wagon
Re: Looking for 93-01 GC8 steering rack rebuild kit.
You know.....I actually may have one. I bought a seal kit for my 97 Impreza to do the steering rack but never used it. Do you have a part number or a year/model range I can double check the seal kit I have against?
It’s for a right hand drive, would they be the same?Legacy777 wrote:You know.....I actually may have one. I bought a seal kit for my 97 Impreza to do the steering rack but never used it. Do you have a part number or a year/model range I can double check the seal kit I have against?
JimBo
Part number is 34110 FE140, I’m also looking for the knuckle so I can cut and weld it together to make it work in my car.Legacy777 wrote:You know.....I actually may have one. I bought a seal kit for my 97 Impreza to do the steering rack but never used it. Do you have a part number or a year/model range I can double check the seal kit I have against?
JimBo
That part # is the entire rack. I found this on Ebay.
https://www.ebay.com/itm/Subaru-newage- ... 3279993902
The kit I have is 34128AA211. I'll take a couple pictures and see if it looks remotely like what you're looking for.
I already have the rack, I just wanted a rebuild kit for it for ease of mind. Like I said I still need to make the linkage work somehow, thanks though
JimBo
Did you check out the seal kit in the pictures above?
Legacy777 wrote:Did you check out the seal kit in the pictures above?
Here’s the part number of the rack, what do you think?
JimBo
Honestly, I don't know. I did a little bit of searching and couldn't find anything specific. Do you know the model and year range that this rack came from?
It says it was for a 93-01 GC8, and yeah I haven’t really been able to find much on it either.Legacy777 wrote:Honestly, I don't know. I did a little bit of searching and couldn't find anything specific. Do you know the model and year range that this rack came from?
JimBo
