EJ20 Series 1 Timing Kit
Post by 0413003 »
Hi can anyone advise a supplier for a timing kit for a Series 1 EJ20GDW1BJ engine code?
Many thanks
Re: EJ20 Series 1 Timing Kit
Welcome!
If you don't get any response here you may want to check out the first gen Legacy groups on Facebook as they are much more active.
0413003
Post by 0413003 »
Hi Josh,
Thanks for the tip.
Barry
arse_sidewards
Post by arse_sidewards »
I just use the cheap aftermarket kits. These engines are non-interference, easy to work on and the belt pretty much always outlasts the idlers in my experience. I don't see the need to spend 3x as much for peace of mind considering how small the potential inconvenience is.
1992 FWD MT wagon, 1994 AWD AT wagon
wtdash
Post by wtdash »
Older post, but everything I've read is that the EJ25D kits will work on the EJ20G.
And as the EJ20G is a DOHC interference, the valves can interfere.
There's also a thread on here devoted to the differences. It's ancient but may be useful: viewtopic.php?t=38247
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
