Looking to purchase a stock injector or a set of stock injectors for an ej22T. I recently picked up a 92 turbo legacy wagon and I am getting the following CELs: 15, 22, 45
I believe the code 15 is saying injector #2 inoperable. The car runs, but is running like crap right now. I also acquired a ton of extra parts I could offer for trade or can pay via Paypal or local meetup (I am in Western PA). Also if anyone has additional insight on the other codes I would love to hear possible fixes! I am more familiar with newer Subarus on OBD2 setups (I have a FXT swapped 01 RS, 2003 WRX, and an 05 Outback XT).
Troubleshooting Stock ej22T injector (or injectors)
Re: Want to buy: Stock ej22T injector (or injectors)
Welcome to the BBS.
My recommendation would be to reset the ECU/clear the codes and then check the codes again to see what codes come back. Typically you work to address the lower code first.
Please take a look at the instructions on my site for clearing the codes:
https://www.surrealmirage.com/subaru/engine.html
Check out this scan for testing the injector's resistance and wiring.
https://main.experiencetherave.com/suba ... iagram.pdf
If you still need an injector please create a post in the Parts Shed forum. (I revised your topic title)
Re: Troubleshooting Stock ej22T injector (or injectors)
Can confirm, dead injector no.2. Happen to have any for sale legacy777?
I don't think I have any. We're in the process of moving and I wanted to clean/move the garage this weekend. So if I happen to run across any I'll let you know.
Awesome, I appreciate it!
