Hello, I am making this post because I am doing a drivetrain swap in my 91 legacy and these parts I will no longer need.
Vin 4S4BC63C4M6621880 around 146,xxx miles
That being said everything for sale is in this list.
All components are low milage and in great working order. Unless otherwise specified. For any pictures please DM me.
All New/replacement parts were installed at 138,xxx miles
The engine
I will only sell the engine as a whole.
Ej22e long block (this engine is from a 94 with 74,xxx original miles when installed) oil pan and valve covers re-sealed. The rest is un-opened original.
Intake manifold is 91 but the rails and injectors are 94.
New cam sensor with jumper harness so you can use a Phase 2 sensor. This was purchased and professionally made.
10mm oil pump (used from 02 wrx)
New timing belt, idlers, and Phase 2 tensioner and bracket.
regularly serviced by me.( ngk plugs, oem oil filters and 5w40 oil its whole life except when we had the 12A shortages then it got napa gold oil filters or six star)
The transmission axles and diff
4.11 final drive TY code 752VA1AA
Napa Auto parts CV axles
2003 outback rear diff VLSD
02-07 wrx rear axles with 03 outback ends. ( These are much more available where I am located then oem)
oem drive shaft.
Non-abs knuckles, wire wheeled and painted in pour15, new Koyo bearings and seals. Will not come with ball joints.
transmission mount is custom and semi solid. The secondary mounts are poly.
Shift linkage received a new cup, oring, clip and pivot ball. Main assembly is 05 sti the pivot arm is 02 wrx and the linkage rod is legacy and the little bushings that connect the 2 rods.
Shifter U-joint replaced with an oem part.
Clutch is of unknown origin or miles the previous owner replaced it and seemed to be very new when I re-used it.
Brakes have been serviced. Fronts are 02 wrx rears are stock.(will not come with track pads)
The Exhaust
I am not proud of this part of the build but it is a Chinese UEL header with many modifications to "fit" (it really doesn't fit) hahaha.
The Front subframe and rack.
The front subframe is 07 Forester and a reman power steering rack from napa. will include ps pump ( original to the car but I have the low mile one as well) and lines.
will not include outer tie rod ends.
This will require some GD parts to make work on your first gen so personally I would just run the oem subframe.
Pricing. I would like to get $1000 for everything. That being said I care more about these parts finding a good home where they wont just lye on a shelf until the end of time.
							Complete drivetrain for sale.
Austin
1991 Subaru Legacy
SCCA midwest region
SCCA Rocky Mountain region
Based in Colorado
						1991 Subaru Legacy
SCCA midwest region
Based in Colorado
