Hi, 90 legacy ls AWD, everything feels good n smooth except when I'm turning there is a vibration. Comes through the steering wheel. I can't figure out what's causing it, only happens when I'm making a sharper turn.
I pulled back the boots on the caliper slides and greased them, but didn't remove them fully to grease.
Any help I'd appreciate it.
Edit: just drove another 30 km and didn't experience the shudder turning hard into a gas station, so maybe it's just the pads breaking in.
Everything thing else has felt fine, same as before the replacement.
Just replaced front pads calipers and rotors
arse_sidewards
Re: Just replaced front pads calipers and rotors
Probably shudder in the AWD clutch if automatic or coupling if manual. Nothing to worry about.
Swap tires front to back and see if that changes anything.
1992 FWD MT wagon, 1994 AWD AT wagon
